Help please :)
Started by HaB Stealth0, December 29, 2004, 11:27:47 PM
HaB Stealth0
When  i try and open a track in normal armadillo it comes up with "Unable to read Project Files".
All ive done is completed the disp map and placed objects (176) of them. Saved and quit armadillo.
Opened armadillo again and tried to open but that error popped up.
I havnt edited any files in the project file  :-\
Maybe its the objects i used (mainly the THQ pack by Myth)
I have no clue, so any help would be apreciated :)
Thanks,
Stealth
tw0_f0ur_
looks like you forgot to run Armadillo Project Manager
Thanks,
     tw0_f0ur_ l MXR_DeAt_ l tw0gh0st
HaB Stealth0
huh? im not bundling it..
ive done this millions of times with custom objects and worked fine. but this time its screwed. Armidillo just seems to get worse every track i make with more errors..
tw0_f0ur_
still need to run it through APM
Thanks,
HaB Stealth0
ive ran it through APM, first time error came up.. fixed that it didnt have the .TDF file in project file..
So ran it again.. process wat all good.
Got into Armadillo. Still came up with "unable to read Project File"
Thanks,
Stealth
tw0_f0ur_
its beacuse ur prj file was already bad and then u went and messed it up in AMP more.. sounds to me ur gonna have to start over. just make a new PRJ and take the object file from the old prj to the new one. just rename it
Thanks,
HaB Stealth0
hmm i done that now it just quits armadillo.. oh well i just have to redo it..
just a question, is their an object limit that armadillo will except?
BombX3
Think its like dont use over 200 custom objects, amount of stock objects im not sure guess its unlimited :P
MDx_chris774
i have had the same problem quite a few times, what i do is delete the scn file, that works
for me, another way is to have at least one custom object, on your track,when you place your stock objects, the problem seems to be with the stock objects..
hope this helps you regards chris
