MVA Track Map Bug Fixer
Started by DirtTwister, January 20, 2006, 07:38:29 PM
KungNisse
OK starting to talk about snow xD.
Well i got this problem with (trackname).pak.bak    What to do?:O  And there is no way i can get the picture from view2D/texture?
Hope this thread is still alive lawl.
Not sure what you're asking for, which picture and what do you want to do with trackname.pak.bak?
KungNisse
After doing whats this program should do, the track renames itslef to (trackname).pak.bak .      Should it be named likte that? Is it just to re-name it to (trackname).pak again or whO.ot?
I don't build tracks so I haven't used the map fixer, but from what i know of Bruce's work i would suggest that the file renamed xxx.pak.bak is a back-up of the original track in case there was a problem and you needed the original again. Rename it to xxx.pak and i think you will find it's your track before the map fix is applied.
Laurie
KungNisse
I think i get it what he talking about "bruce". But can i delete the xxx.pak.bak. ? What I understand its just something random i can delete and just go and have fun with my Fixed map in the (trackname).pak     While the (trackname).pak.bak is trash.
Quick answer pleas :)
Fixer
the *.bak is just a backup in case something goes wrong for some reason...
KungNisse
like what? :) If the tracks stop works? :O Kinda had that problem after that lol.
And if that way. you mean thats the ORIGINAL of the track,( the (trackname).pak.bak  ) ?
Quotelike what?  If the tracks stop works?
Yes, if after using the Map Fixer the xxx.pak works then xxx.pak.bak is trash, otherwise delete xxx.pak and rename xxx.pak.bak to xxx.pak and you have the original track back..
The program copies xxx.pak and renames it to xxx.pak.bak before fixing xxx.pak.
KungNisse
ok nice. TY alot . BTW when i reanamed the xxx.pak.bak to xxx.pak i couldnt se the track in game. But whatever!  I think when I fix the tracks with the map fixer, the xxx.pak will always work.
Make sure that you rename it so that the trackname is exactly the same as the old name otherwise that can cause some problems like track not appearing in the list.
KungNisse
Ok. Thank you everybody for helping me :D
